I have 92 just re done the top end came with K & N air filter and Dg pipes..on it when I got it. stock jet is 200 any idea what Jet I should use now? It seems to break up about mid to full throttle maybe not break up but just runs out of gas.. Do I go up to 210 or down.. 190? Thanks
sounds like you need to go up a few jet sizes. if your airbox lid is off probobly around a 260?
I just got done rebuilding on with just minor bolt on mods....pipes, coolhead. and K&N air filter. It also had stock jets in it when I bought it AND it had a melted spot on the piston probably from the stock jets running me too lean. After talking with Jeff at FAST and reading a great sticky in here about jetting, I ordered 300 main jets and 27.5 pilot jets. Runs sweet now. The jets are cheap and 2 days after I ordered them they were in my mailbox. Dont screw up your new topend. Call FAST Racing . I will post the link to the HQ sticky. Good luck.
Banshee Jetting FAQ
Thanks thats what happen before burned the piston on the right side.
Banshee Jetting FAQ
