thebrittishguy Posted March 8, 2012 Report Posted March 8, 2012 (edited) Hi I have a set of 38mm Lectrons from fast by gast that I bought off "tz racin" I believe it has a power jet or dial a jet I need help getting the correct needle for my setup please. As I’m based in South Africa I want the best chance of getting the correct needle first time rather than having to purchase multiple needles when there is only 1 Please see my setup below and recommend which needle I should get. 4mm 115 Hotrod crank trued and welded Set of Rocket R2 pipes 38 Lectrons Fast by gast with Dyna-tech FS Programmable CDI Adj timing plate set to +4 Vforce 2 Reed Valves 4mm dune port cylinders 65.5mm Pro Design Coolhead (19cc custom cut for 4mm port) Tors Removed Air box lid off Snorkel off 6000 ft above sea level If you need any other info, please don’t hesitate to ask. Any help will be much appreciated, thank you in advance. Edited March 8, 2012 by thebrittishguy Quote
camatv Posted March 8, 2012 Report Posted March 8, 2012 your best bet is to call PACKARD and get the needles they recommend. sometimes it necessary to get 2 sets and switch them out and then play with the settings to get it dialed in. id GUESS you'd need 3-1 xl. but i may be wrong. also with those style of pj's you need to be very careful with the screw in the top it CAN unscrew all the way and fall out (YIKES) and cause all kinda of issues. a clippard style pj cannot come out and in my opinion is a much better setup.. just a suggestion. BUT of course you'd have to send them in somewhere and have them installed,. Quote
thebrittishguy Posted March 8, 2012 Author Report Posted March 8, 2012 thanks for the reply! Lectrons in South Africa are non existent, no-one knows about them which makes support or supplies rare and difficult. (yet rare which is why i want them!) i have sent Dennis a few emails as well as the guys from FGB (sales) with no reply as yet. thanks again and i hope to get more feedback to steer me in a direction. Quote
DallasGDub Posted March 8, 2012 Report Posted March 8, 2012 Dennis Packard not only sold me the right needles and cable, he got me within 2mm in setting it. 801-451-6142 http://www.packardracing.com/ Quote
thebrittishguy Posted March 9, 2012 Author Report Posted March 9, 2012 heres hoping he can find the time to reply to an email :-) otherwise ill have to sit up at a random time one evening and call. Quote
rubberneck Posted March 9, 2012 Report Posted March 9, 2012 I was running a dune ported 4mil with cpis at sea level and dennis sent my lectrons with a 4-2XL needle. they are 34 mm and im not sure if that will make much of a difference. I would just call him. He picked right up when i called, never tried email Shit never mind just saw you posted that you are at 6000 feet, my post has no relevance to you sorry Quote
thebrittishguy Posted March 15, 2012 Author Report Posted March 15, 2012 guess i will have to phone dennis as noone has got back to me from FBG or Packard Quote
camatv Posted March 18, 2012 Report Posted March 18, 2012 sucks your that far away. but he always answers the phone if not leave a mesage. or call again the next day Quote
cattledog Posted March 18, 2012 Report Posted March 18, 2012 (edited) i will contact paul at fast by gast for you as i am 30 minutes from his shop and have our bikes dynoed by one of the best lectron tuners in the states that does his stuff also . i am shocked paul gast has not replied to you as he is a stamd up guy, i s Edited March 18, 2012 by cattledog Quote
thebrittishguy Posted March 18, 2012 Author Report Posted March 18, 2012 thanks cattledog, that is very kind of you. i have had a reply from Dennis Packard, i will post it below incase it helps anyone and id also be interested to see what FBG has to say. Dennis Packard on my setup and tuning- I would recommend 4-2 needle and setting the needles at 51.8 MM. This measurement is taken from the tip of the needle to just off of the side of the brass insert on the bottom of the slide. So, in other words, you need to be on the gray colored slide material in arriving at the measurement. I don't know what kind of ajustment system you have for the power jets. If it is a fixed power jet with interchangeable Mukine pilot jets, for your altitude, I would start with a number 30. Because of your altitude (6000 ft), you will probably need to lien the needle from the 51.8 setting by approximately 1/2 turn. That means by turning the needle in the fully extended position 1/2 turn counterclockwise. Remember, the flat part of the needle always has to be facing the motor. This is achieved by pushing the needle in with your fingers and turning it to that position. In doing this, it doesn't change the tuning because the whole mechanism internally spins. all mods are in the first post above - everything i know anyway :-) will get back to you on the tire sizes. thanks all for the help, really nice to have decent people willing to lend a hand Quote
