FrankieSquid Posted March 8, 2012 Report Posted March 8, 2012 Sup HQ. I just finished adding new bearings and seals to my (stock) carrier. Is there suppose to be some sort of dust covers on both sides. Right now I have the big spacer in the carrier then the bearing and followed by the seal. Is there something (dust cover) that goes between the sprocket hub and the seal, as well as somethin between the brake hub and seal. Thanks. Quote
11AGUY Posted March 8, 2012 Report Posted March 8, 2012 just did it a few weeks ago.... there is no dust cover... remember the sprocket/brake hub has a small lip that goes inside the carrier and gets sucked into place when you tighten your axle nuts (keeps debris out)..... just make sure you put the bearings in straight and the spacer does have to have some free play between the bearings Sup HQ. I just finished adding new bearings and seals to my (stock) carrier. Is there suppose to be some sort of dust covers on both sides. Right now I have the big spacer in the carrier then the bearing and followed by the seal. Is there something (dust cover) that goes between the sprocket hub and the seal, as well as somethin between the brake hub and seal. Thanks. Quote
FrankieSquid Posted March 8, 2012 Author Report Posted March 8, 2012 Makes sense, I tend to over analyze shit. Thanks Guy Quote
