fuzzypickles Posted March 7, 2012 Report Posted March 7, 2012 I bought a used big bore top end kit and everything is absolutely perfect, shiny, and you can still see the cross hatching. But, there is damage to the top of one of the pistons. Not sure how it happend, but I need to get a new one. Anyway, they are 68.50mm bore. The cylinders appear to be stockers sleeved with a Vito's 404 kit or something. They are the cast pistons for this kit, not the Wiesco forged pistons custom made for the kit. Anyway, does anyone know what other 68mm big bore pistons would be safe to use for this kit? Vito's wants $63 plus shipping per piston w/rings and $20 for a set of rings. I was gonna buy a single piston/rings for 1 cylinder, and another set of rings for the other cylinder. I was also gonna buy a jet kit from vito's, which would cost me $50. I of course would need a top end gasket set ($30?). If I can find a cheaper set of rings and pistons than the ones from Vito's I would gladly buy those instead. Quote
camatv Posted March 8, 2012 Report Posted March 8, 2012 its most likely blaster pistons but try to source some forged pistons either way your looking at about 80-110 per piston kit ( with rings). Quote
BANSHEE HP Posted March 11, 2012 Report Posted March 11, 2012 so you would mix match pistons and rings if you could find it cheaper? just buy the piston that belongs in it, a vitos c404-p2 and rings to match. and if you dont like that option you could buy 2 wsm standard pin height 68.5's at $120~ each Quote
