your going to get some different answers here......
i don't believe the cdi has a rev limiter in it....... however some will say that the TORS system or the parking brake system will limit the revs....basically making it a rev limiter. BUT then you'll also get others who say that the parking break and TORS are not a rev limiter at all......its a little confusing haha.
Are you having a problem with a rev limiter type of issue on your bike or are you just curious?
The cages on the reeds will limit the engine rpm, if you remove them you can over rev the engine or bust the reed pedals off- learned that one from experience.
