Ok got my new nut and washer for my sprocket today since I lost my old one, heres the problem it will not tighten looks like the threads might be a lil screwed up anyway to fix it for now until I get a new shaft, anyone know what threader size it is maybe I could rethread it?
how bad are the threads? if the nut wont tighten now i doubt running a die on it will help. try putting a washer between the nut and sprocket? maybe the outer threads are in better shape
just seems like the threads are skipping? I remember trying to locate a nut ASAP as mine had removed itself and never found anything close at a hardware store so im not sure its a standard thread.
let me know if you end up needing a shaft. i have one ill send you for cheap.
How hard is this to do aswell this would be my first one I have done, I am mechanically inclined and have done a crank before so should be a piece of cake?
not much harder, just need a good pair of snap ring pliers to swap the gears over.
For the time being I tightened it in as best as I could, and then I also locktited the nut think I could get away with that, also thought about just throwing a tack weld on the end of the nut to get me by for now.
had the same damn problem... not sure what the deal is???? I stripped one and had to cut the nut off with a dremel tool.... seems like this is a common problem
Yes it is common for people that don't use a torque wrench. Every fastener on a Banshee has a torque spec. If you use a torque wrench instead of an impact wrench, along with a little Loctite, you won't have a problem with fasteners stripping or coming loose.
I never had a torque wrench nor a impact on mine I always tightened it by hand but this poor machine was sadly abused by the previous owner/owners, I mean hey I did get it for a couple hundred bucks so far I have done the following since buying it a few months back. Complete top end, cylinders,pistons,rings,gasket kit,reeds and cages,filter,tors removal,bearings all the way around,just installed a seal behind the sprocket, installed a new chain and sprockets,complete swing arm rebuild kit with new carrier,head pretty soon I should have a brand new machine HAHA. I also installed tors removal kit aswell tires all the way around but hey for 400 bucks I couldn't complain I guess.
if you are worried the nut might come off during riding a small tack weld would hold it or you could jam some lead strips inside the nut so it grabs the threads a little better. if it were me and you are going to change the shaft out i would just put 2 or 3 decent tacks on the nut/shaft and call it good
oh and get a damn torque wrench, they are cheap and save money in the long run. im used to working on heavy equipment so i have a habit of over tightening shit on small stuff so i need a torque wrench
I am just saying that somebody( not neccassarily you) either overtightened it and stripped it or under tightened it so it came loose and damaged the threads.
