Jeremy_bell_banshee99 Posted February 27, 2012 Report Posted February 27, 2012 I need to get my steering stem bearing out, tried beating it out but wont work? What will help? Quote
cline Posted February 27, 2012 Report Posted February 27, 2012 I just viewed a discussion not to long ago and there were at least three different devices used by different members that seemed to produce the same result.......removing the bearing successfully. Other than that I will beat the dead horse and say what I have already read from all the other wise men on here a million times. Get yourself a clymers manual which is a banshee owners must have tool to be added to you tool box. Heres the link to the discussion hope it at least gets you started or helps some. http://bansheehq.com/forums/index.php?showtopic=151491&st=0&p=1310413&hl=+steering%20+stem%20+bearing&fromsearch=1entry1310413 Quote
andrew3160 Posted February 27, 2012 Report Posted February 27, 2012 You have to take the threaded retainer out then take a socket the diameter of the outside of the bearing and beat it out. I welded a socket onto a hex head bolt the size of the retainer. Some just use a couple jam nuts on the hex bolt to give you something you can grab onto with a socket or wrench. The thread provided should shed some light on this. Quote
