I run K&Ns in the sand because I have seen a video of sand grains actually making their way through the pores of a foam filter. I use an Outerwears and have NEVER had dirt in my carbs. I also use a K&N in my pickup and never have dirt in the intake tubes. Just make sure you mount them so they don't rub and when you clean them don't blast them with high pressure water of air. Use a low flow stream of water, just enough to rinse out the cleaner and dirt and then just set it somewhere warm until it is dry.
Im a little different because I run a single carb set up. But I run a 6 in long by 5.5 in wide round k&n pod. Then I put a a foam prefilter over it. The foam stops up quick, but its cheap so I just carry three of them. They last me a good long ride easy.
