phil1985 Posted February 23, 2012 Report Posted February 23, 2012 I recently bought a 2001 banshee i has a coolhead fmf gold series pipes power core 2 silencers Barnett clutches.boost bottle oversized radiator..k&n filter kit are there any other mods i can do with out having to open up the motor Quote
Jereme6655 Posted February 23, 2012 Report Posted February 23, 2012 Air filter and +4 timing. Also you should upgrade the suspension.....the faster you can go over the bumps equals the faster you are overall. Also make sure you do maintenance and use quality products in your bike. It will pay off in the long run. And I would also make sure the jetting is correct and that there are no air leaks. Quote
06specialedition Posted February 24, 2012 Report Posted February 24, 2012 Your going to open the motor up someday anyways....port it! Quote
SNTBANSHEE Posted February 24, 2012 Report Posted February 24, 2012 Get a Clymers repair manual and dump the boost bottle. Quote
Larry's Shee Posted February 24, 2012 Report Posted February 24, 2012 Read LOTS of threads on here. Educate yourself. Then you don't have to ask redundant/stupid questions . You need to be honest with yourself and build within your needs/budget. Quote
Bkm2006 Posted February 24, 2012 Report Posted February 24, 2012 Just do a leakdown, sync carbs, do compression check, do a plug chop. Then ride it like u stole it!!!!! Save ur money then when its time for a rebuild contact a site sponsor Quote
phil1985 Posted February 27, 2012 Author Report Posted February 27, 2012 Thanks guys..i had it at the dunes today and yur right it runs awesome so ill leave it and wait to upgrade when i need to rebuild Quote
