Toomanytoys Posted February 16, 2012 Report Posted February 16, 2012 I have an 01 421 stroker.Was built by another BHQ member. It has a detonated piston but still ran {not seized} I was told it has straight cut trans It doesnt use the spacer plate,Domes were cut for clearance. K-T Ported cylinders At minimum needs piston and ring or possibly needs a rebuild. I only have the domes for the coolhead you will need the actual head. Crank is a Hot-Rods and again was told it was Trued-Welded Takes the 795 series wiesco's Does not include stator/mag or side covers No carbs-pic in CL ad here http://scranton.craigslist.org/mcy/2847536141.html Pickup Only in Wilkes-Barre Pa 18702 57o-3six2-37eight5 Quote
Infamous039 Posted February 16, 2012 Report Posted February 16, 2012 $1,300 ??? Sounds like a ripoff to me. I think you will be more in the area of $500-600 for the setup. Theres probably over that much to get it fixed and running. Quote
Toomanytoys Posted February 16, 2012 Author Report Posted February 16, 2012 $1,300 ??? Sounds like a ripoff to me. I think you will be more in the area of $500-600 for the setup. Theres probably over that much to get it fixed and running. Needs a piston and ring.Doesnt sound fucked to me. I guess everytime a piston detonates the motor is Fucked and should be thrown away.Fuck You Quote
sandman125 Posted February 16, 2012 Report Posted February 16, 2012 Needs a piston and ring.Doesnt sound fucked to me. I guess everytime a piston detonates the motor is Fucked and should be thrown away.Fuck You well it not tottally screwed but if you are going to do it right the engine has to be pulled apart seals cranks inspected at a minimum inspect the bore ect and the 500 to 600 doller range is more in the range. I would not buy a blown motor for more than that cuz it will cost you that much more to have it torn apart to insure the motor is good to go if you just do the topend and you have a bad crank seal, bearing, you have just thrown away 300 bucks worth of pistons and bore. just my 2 sents Quote
hp2000 Posted February 16, 2012 Report Posted February 16, 2012 Pictures of what's included and the damage would help your thread just my opinion. Quote
lms1977 Posted February 16, 2012 Report Posted February 16, 2012 good luck with the sale at 1300 it wont ever sell on this site for that much Quote
Phelps Posted February 16, 2012 Report Posted February 16, 2012 better question would be.... is it a 421? you said 4mil stroker. ok is it a 68mm stock cylinder? Quote
Infamous039 Posted February 16, 2012 Report Posted February 16, 2012 Motor looks torched $1300 is way to high. Motor needs to be completely inspected and rebuilt. This is what I consider a crack head deal, meaning the person who purchases must be on crack to spend $1300 on it. Quote
shakar Posted February 16, 2012 Report Posted February 16, 2012 better question would be.... is it a 421? you said 4mil stroker. ok is it a 68mm stock cylinder? i would never imo buy a engine that says 'well.... thats what i was told '' in the parts list goodluck though Quote
rjdgriff Posted February 16, 2012 Report Posted February 16, 2012 Bahahaha hahaha haha... For that kind of money someone could EASILY turn their stocker into a trustworthy 4mil Quote
421alkybanshee Posted February 16, 2012 Report Posted February 16, 2012 I would be afraid to even ask any questions about this engine. Its obvious he doesnt know much about banshees since that is not a straight cut gear on the basket and he probably doesnt know the exact bore,stroke,etc of the rest of it. Good luck man, you might want to try screwing someone on another site though!! Lets keep honest people and honest business transactions a must here. my .02 cents Quote
rjdgriff Posted February 16, 2012 Report Posted February 16, 2012 I would be afraid to even ask any questions about this engine. Its obvious he doesnt know much about banshees since that is not a straight cut gear on the basket and he probably doesnt know the exact bore,stroke,etc of the rest of it. Good luck man, you might want to try screwing someone on another site though!! Lets keep honest people and honest business transactions a must here. my .02 cents x2 Quote
guns4children Posted February 17, 2012 Report Posted February 17, 2012 Better luck selling a boost bottle on here then a 1300 Buck junk motor. Quote
