Ifyouaintfirst....urlast Posted February 11, 2012 Report Posted February 11, 2012 When i go to crank my banshee its stuck, and the rear tire will roll without the clutch held in. Idk what the problem may be or if i could just fix it myself Quote
Larry's Shee Posted February 11, 2012 Report Posted February 11, 2012 Welcome to BHQ !! All questions answered free. Correct answers cost more. There is a download manual somewhere around here or pick up a Clymers repair manual. Start by draining trans fluid, probably needs changing anyhow. Drain coolant, remove clutch cover and search for broken pieces. Did it stop while you were riding?? Or you went to start it and kicker won't work. Try to include as many details as possible when asking a question. Quote
Ifyouaintfirst....urlast Posted February 11, 2012 Author Report Posted February 11, 2012 Welcome to BHQ !! All questions answered free. Correct answers cost more. There is a download manual somewhere around here or pick up a Clymers repair manual. Start by draining trans fluid, probably needs changing anyhow. Drain coolant, remove clutch cover and search for broken pieces. Did it stop while you were riding?? Or you went to start it and kicker won't work. Try to include as many details as possible when asking a question. Yes it did stop while i was riding it Quote
Larry's Shee Posted February 11, 2012 Report Posted February 11, 2012 Either you blew clutch basket or kicker idle gear blew taking out clutch basket. Pull clutch cover and take a look. Quote
Ifyouaintfirst....urlast Posted February 15, 2012 Author Report Posted February 15, 2012 Alright ill check it out and see...been busy lately Quote
