Shifting problems
4mildkue
You will need modded star, cut tranny, good shift shaft, & billet basket according to what members on here told me. I have modded star & cut tranny but it still didnt help me shift from 1st to 2nd under high RPM's. Far as best tranny to get I would go with an over-ride tranny set-up to your liking. Im going to try new shift shaft & billet clutch basket, then I will let you know how it turns out. Good luck on getting that thing to shift I know the feeling. I kept losing to a modded yfz450 because of the shifting issue.
Edited by 252wheelieking
by cut trans.. do you mean a overide?
If your drag racing.. a overide is a MUST!
I'm having problems shifting from 1st to 2nd on my drag ported 4mil...will the shift star work or should I just get a cut trans if so witch is the best for the 1/8 asphalt
hey man.. i had the same problem on my shee.. turned out that the eccentric stud was out of adjustment.. once i got it adjusted properly it shifted like a charm :headbang: hope this helps!
