4mildkue Posted February 8, 2012 Report Posted February 8, 2012 I'm having problems shifting from 1st to 2nd on my drag ported 4mil...will the shift star work or should I just get a cut trans if so witch is the best for the 1/8 asphalt Quote
4mildkue Posted February 8, 2012 Author Report Posted February 8, 2012 So what the best trans for the 1/8 Quote
252wheelieking Posted February 8, 2012 Report Posted February 8, 2012 (edited) You will need modded star, cut tranny, good shift shaft, & billet basket according to what members on here told me. I have modded star & cut tranny but it still didnt help me shift from 1st to 2nd under high RPM's. Far as best tranny to get I would go with an over-ride tranny set-up to your liking. Im going to try new shift shaft & billet clutch basket, then I will let you know how it turns out. Good luck on getting that thing to shift I know the feeling. I kept losing to a modded yfz450 because of the shifting issue. Edited February 8, 2012 by 252wheelieking Quote
shanYE west Posted February 8, 2012 Report Posted February 8, 2012 You will need modded star, cut tranny, good shift shaft, & billet basket according to what members on here told me. I have modded star & cut tranny but it still didnt help me shift from 1st to 2nd under high RPM's. Far as best tranny to get I would go with an over-ride tranny set-up to your liking. Im going to try new shift shaft & billet clutch basket, then I will let you know how it turns out. Good luck on getting that thing to shift I know the feeling. I kept losing to a modded yfz450 because of the shifting issue. by cut trans.. do you mean a overide? If your drag racing.. a overide is a MUST! Quote
special06shee Posted February 8, 2012 Report Posted February 8, 2012 I'm having problems shifting from 1st to 2nd on my drag ported 4mil...will the shift star work or should I just get a cut trans if so witch is the best for the 1/8 asphalt hey man.. i had the same problem on my shee.. turned out that the eccentric stud was out of adjustment.. once i got it adjusted properly it shifted like a charm hope this helps! Quote
4mildkue Posted February 8, 2012 Author Report Posted February 8, 2012 Oh ok rdz told that I was making to much hp to have a stock tranny but I was wondering if there were ways around it but I was kinda of hesitant about the override because I heard they will tear up Quote
sleeper06 Posted February 8, 2012 Report Posted February 8, 2012 When you star making power all the lil nonsense mods wont help at all, irun asphault mostly 1/4 tho.I would recommend a dunable 1-4 overide 5th 6th clutch for 1/4 .If your gonna run strictly 1/8 you can get away with a 1-5 overide hit me up if you have any questions Quote
4mildkue Posted February 8, 2012 Author Report Posted February 8, 2012 Ok thanks man I'll guess ill just find one on here and buy it Quote
4mildkue Posted February 8, 2012 Author Report Posted February 8, 2012 I ran 6.93 at 93mph in the 1/8 on my 4mil stock cylinder on race gas and with the shifting problem...so with alky and a cut trans do anybody have ideas on how fast my bike will pick up Quote
