JdmNinja Posted February 4, 2012 Report Share Posted February 4, 2012 I need some adjusting help plz, I have an 05 banshee and I just installed a Tors removal Kit. maybe i missed something here but every time i start it ,it wont stay idle. Quote Link to comment Share on other sites More sharing options...
NetBSD Posted February 4, 2012 Report Share Posted February 4, 2012 did you install the idle screws and adjust them? to install the screws you need to drill and tap the carbs. to adjust just keep turning the idle screw in untill it idles smoothly, do the same for other cab and check sync Quote Link to comment Share on other sites More sharing options...
Broke_Banshee Posted February 4, 2012 Report Share Posted February 4, 2012 choke tube between the carbs on????? Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted February 4, 2012 Report Share Posted February 4, 2012 IF you installed the screws and they are screwed in all hte way, you probably need to grind more of the shoulder off that you tapped. That seems to be the most common mistake. Hope that helps. Quote Link to comment Share on other sites More sharing options...
JdmNinja Posted February 5, 2012 Author Report Share Posted February 5, 2012 I think the problem was that I forgot to unplug the tors main brain box. now my shee stays on . but now with both idle screws all the way in isnt my shee supposed to be at very high idle?? its sounds normal . so should i grind off a bit more ? Quote Link to comment Share on other sites More sharing options...
muggzy Posted February 5, 2012 Report Share Posted February 5, 2012 I think the problem was that I forgot to unplug the tors main brain box. now my shee stays on . but now with both idle screws all the way in isnt my shee supposed to be at very high idle?? its sounds normal . so should i grind off a bit more ? Yeah, take another 2mm from each carb body. Quote Link to comment Share on other sites More sharing options...
