did you install the idle screws and adjust them? to install the screws you need to drill and tap the carbs. to adjust just keep turning the idle screw in untill it idles smoothly, do the same for other cab and check sync
I think the problem was that I forgot to unplug the tors main brain box. now my shee stays on . but now with both idle screws all the way in isnt my shee supposed to be at very high idle?? its sounds normal . so should i grind off a bit more ?
Yeah, take another 2mm from each carb body.
