Tdevlin14 Posted January 31, 2012 Report Posted January 31, 2012 On the top of my stock carbs (tors eliminated), there is an adjuster that the end of the throttle cable sits in that snapped off. Does anyone know where to find this? And also the float needles? I have a nice steady stream from the overflow.... Quote
Jereme6655 Posted January 31, 2012 Report Posted January 31, 2012 On the top of my stock carbs (tors eliminated), there is an adjuster that the end of the throttle cable sits in that snapped off. Does anyone know where to find this? And also the float needles? I have a nice steady stream from the overflow.... You need either a new set of TORS units.....or a TORS eliminator kit. Eventually if you hang on to your bike long enough you are going to need to take the TORS off or at least replace them again as it seems that everyone here has had a problem with them at one time. They can cause everything from a fake rev limiter feeling to a no run situation. True you can just unplug them.....however then you have those big clunky things on top of your carbs that make it WAY harder to work on. The screw piece that are looking for is actually the idle adjustment. If you go through one of our great site sponsors you can get the TORS eliminator kits that have the new tops for the carbs, the new throttle cable, 2 idles screws, a drill bit and a tap for installation on your carbs.....also instructions Quote
willardwright59 Posted January 31, 2012 Report Posted January 31, 2012 You just need a new cap is what i take from your post. And if you need needles and floats pm me. I have a set of spare carbs with good floats etc ill sell. Quote
bansheesandrider Posted January 31, 2012 Report Posted January 31, 2012 You need either a new set of TORS units.....or a TORS eliminator kit. Eventually if you hang on to your bike long enough you are going to need to take the TORS off or at least replace them again as it seems that everyone here has had a problem with them at one time. They can cause everything from a fake rev limiter feeling to a no run situation. True you can just unplug them.....however then you have those big clunky things on top of your carbs that make it WAY harder to work on. The screw piece that are looking for is actually the idle adjustment. If you go through one of our great site sponsors you can get the TORS eliminator kits that have the new tops for the carbs, the new throttle cable, 2 idles screws, a drill bit and a tap for installation on your carbs.....also instructions It says in parentheses that the TORS is eliminated. You should be able to get the cable adjuster from Motion Pro. You can get the needle and seats from Yamaha or from PJ Motorsports,http://www.pjmotorsports.com/keihin-mikuni-needle-valves.html#Yamaha,they are a site sponsor. Quote
Jereme6655 Posted January 31, 2012 Report Posted January 31, 2012 It says in parentheses that the TORS is eliminated. You should be able to get the cable adjuster from Motion Pro. You can get the needle and seats from Yamaha or from PJ Motorsports,http://www.pjmotorsports.com/keihin-mikuni-needle-valves.html#Yamaha,they are a site sponsor. Shit. Good call sand rider....It was early....haha... Ya now I see that one.....damnit I need more coffee in the mornings.... Quote
