ironmike Posted January 30, 2012 Report Posted January 30, 2012 my banshee will not snap up no pwer band i change the carbs and cant get it right i put keihin pwk s46a1 rhl that is only thing i could find on them i think they are 36 mm anyone know where i should be this is a drag bike has out of frame drag pipes k/n air filters thanks for any help i am new at this Quote
Larry's Shee Posted January 30, 2012 Report Posted January 30, 2012 Are the jugs "stock" as your title says or are they ported stock jugs? Quote
ironmike Posted January 30, 2012 Author Report Posted January 30, 2012 (edited) Are the jugs "stock" as your title says or are they ported stock jugs? sorry larry the have a clean up but thats it stock head to Edited January 30, 2012 by ironmike Quote
ironmike Posted January 31, 2012 Author Report Posted January 31, 2012 sorry larry the have a clean up but thats it stock head to pilot is 45 main is 135 Quote
Larry's Shee Posted February 3, 2012 Report Posted February 3, 2012 I'll bet your carbs are to big. Without enough "motor" to use those carbs you won't have high enough velocity to jet properly coupled with pipes that want more ex timing/area. Do you by chance have a set of stock carbs to put on it? Quote
ironmike Posted February 5, 2012 Author Report Posted February 5, 2012 I'll bet your carbs are to big. Without enough "motor" to use those carbs you won't have high enough velocity to jet properly coupled with pipes that want more ex timing/area. Do you by chance have a set of stock carbs to put on it? larry i think i got it put 38 pilot and lowerd needle clip was on very bottom so if not then i am going to try to fine smaller set Quote
