2004LEBanshee Posted January 30, 2012 Report Posted January 30, 2012 Does anyone know if the neutral switch cover stay on under the case saver when you install it? I kept it on and couldnt get it to stop leaking. I just purchased a billet neutral cover incase the stock plastic one was the problem. Quote
crustydemon Posted January 30, 2012 Report Posted January 30, 2012 I left my old cover on with a plastic mod quad case saver and dont have any leaks. Quote
BigRed350x Posted January 30, 2012 Report Posted January 30, 2012 Does anyone know if the neutral switch cover stay on under the case saver when you install it? I kept it on and couldnt get it to stop leaking. I just purchased a billet neutral cover incase the stock plastic one was the problem. Sounds like the o-ring on your neutral switch cover is worn out. - Jared Quote
2004LEBanshee Posted January 30, 2012 Author Report Posted January 30, 2012 Sounds like the o-ring on your neutral switch cover is worn out. - Jared I hope your right. I purchased a new o-ring and a billet cover. Hope this solves the problem. Quote
wfobasheeboy Posted January 30, 2012 Report Posted January 30, 2012 X2 on the o-ring on your neutral switch cover is worn out. Quote
