350 screamer Posted January 25, 2012 Report Posted January 25, 2012 (edited) im doing different lights, im stumped here iknow that green is high beam, but wat goes to wat black wire and white wire on the light side green,black,yellow on the connection on the banshee ? picture on the craigslist URL................ lol quickest thing i thought of to post a pic, file was to big on here http://worcester.craigslist.org/rvs/2818173849.html Edited January 25, 2012 by 350 screamer Quote
Larry's Shee Posted January 25, 2012 Report Posted January 25, 2012 Black is ground. Can use either or both to the white. Quote
350 screamer Posted January 25, 2012 Author Report Posted January 25, 2012 Black is ground. Can use either or both to the white. so black and green go to black, wata bout 1 left on each side? cutem off? orrrr? Quote
Larry's Shee Posted January 26, 2012 Report Posted January 26, 2012 Sorry, by both I ment yellow or green to white. Quote
bansheesandrider Posted January 27, 2012 Report Posted January 27, 2012 so black and green go to black, wata bout 1 left on each side? cutem off? orrrr? I would hook up BOTH the green and the yellolw to the white wire on the lights. That way it won't matter if you have the switch on high or low beam. Quote
sheerider11 Posted January 27, 2012 Report Posted January 27, 2012 I hooked up just the low, this way I can either push the switch to the middle or pull it from the high beam which is now another off position. Quote
