stroking Posted January 15, 2012 Report Posted January 15, 2012 got a cub that keeps running hotter on the left side temp is 94 on L and 79 on R after full throttle pass...checked with lasers gun shearers big bore 7mil cub alky 41pwks....tried different carbs and got the same reading compression 210psi on both sides i checked for leaks and found none.....except the oring around the pipes flange,but i doubt that would cause this problem also fuel pump line is tapped on right side (cooler side) Quote
