Frank the tank Posted January 5, 2012 Report Share Posted January 5, 2012 I have a 1987 banshee I just changed the head lights due to a crash last april I got the bike started runs good but as soon as a rev it up it blows my lights out I searched here and the mention the voltage regulator I swapped out the voltage regulator from my other banshee 1989 and also installed a replacement headlight and it still killed my head light im in the ontario ca area if thre anyone that can help me or point me in the right direction i would highly appreciate frank Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted January 5, 2012 Report Share Posted January 5, 2012 check all the wiring and grounds, and if the regulator has a good ground. get it running and check the voltage also check the lighting circuit for resistance from the stator. maybe pull the globes out and keep putting one back till you blow them, then check that circuit. there should be a blue wire going to the regulator, that blue wire changes into yellow. and the yellow is for the lights. Quote Link to comment Share on other sites More sharing options...
Frank the tank Posted January 6, 2012 Author Report Share Posted January 6, 2012 check all the wiring and grounds, and if the regulator has a good ground. get it running and check the voltage also check the lighting circuit for resistance from the stator. maybe pull the globes out and keep putting one back till you blow them, then check that circuit. there should be a blue wire going to the regulator, that blue wire changes into yellow. and the yellow is for the lights. i tried checking the voltage but its not giving me an accurate reading im really stuck !! i checke all the wires all looks good what setting should i have my voltage regulator at ??? Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted January 6, 2012 Report Share Posted January 6, 2012 you should have 12v with a few rpms and not exceed 12v's, at idle its going to be low. Quote Link to comment Share on other sites More sharing options...
