DBR06Banshee10 Posted January 4, 2012 Report Posted January 4, 2012 How many pounds or air to run in the rear of my bike any suggestions???? Quote
wacko2000 Posted January 5, 2012 Report Posted January 5, 2012 Tire pressure is something that will vary often, depends on your setup, what tires your running, what terrain your running etc..... You will air down if you arent hooking enough, air up if you are hooking to much. Just a example on my dirt tires- front Razr2's i usually run like 6psi Rear 22'' super swampers like 3-4psi Rear 20'' razr2's 4-6psi Rear 21'' haulers 3-6 psi This is something you will play with on your own,till you and your machine are comfortable..1psi in either direction makes a big difference Joe 1 Quote
