Bike is ported true n welded crank stock carbs hogged out 390 jetting shearer inframes plugs r burning lik ever racers dream +6 swinger 22x11x8 8paddles geared 14/44 kills on flats n in Tha dunes strong launch from second pulls hard n strong till I get pass half ways up I lose power wen trying to pull away any feed back is greatly appreciated
Stock carbs... you're probably running out of fuel or your jetting isn't perfect. Do you have a pingel or do you still have the junk factory T in the fuel lines? I'd start by pulling the carbs off, clean the crap out of them, check your floats and put a pingel on it if you don't have one already.
- Jared
Guest stimbert
- Jared
x2
