akelly000 Posted December 31, 2011 Report Posted December 31, 2011 Hey guys I have a quick question. A buddy took my cover off to check my timing, it was at +10!! He backed it down to +7. Still too high?? Compression is 145-150, 22cc domes, shitty pipes, pump gas. Quote
Dicklez Posted December 31, 2011 Report Posted December 31, 2011 Most guys keep it at +4. I had mine at +7 with 18cc domes running straight 108 motor octane. If it runs good and doesnt detonate, keep it there. Quote
BigRed350x Posted December 31, 2011 Report Posted December 31, 2011 Hey guys I have a quick question. A buddy took my cover off to check my timing, it was at +10!! He backed it down to +7. Still too high?? Compression is 145-150, 22cc domes, shitty pipes, pump gas. If you are running pump gas I would start off with +4. +10 is pretty high on pump gas. Have you had any signs of detonation? What do your pistons look like? - Jared Quote
akelly000 Posted December 31, 2011 Author Report Posted December 31, 2011 Top of pistons were blackened some with a little build up. Going from +7 to +4,,seems like I lost a little power,,,maybe. What if I get my compression up to around 175-180 with dome change and run 110. Should I go back to +7? Quote
triplethreat Posted January 2, 2012 Report Posted January 2, 2012 Top of pistons were blackened some with a little build up. Going from +7 to +4,,seems like I lost a little power,,,maybe. What if I get my compression up to around 175-180 with dome change and run 110. Should I go back to +7? ported, not ported? carbs, jetting? fuel type? pipes? until all those are answered the timing is somewhat irrelevant. the timing you need will be a result of the entire set up AND the type of riding you do, which will determine the amout of lead time you need for your fuel burn. keep in mind if you up the compression you will need to fuel for it, meaning octane and jetting. it's more complicated than just picking a number or using someone elses number! Quote
mpd579 Posted January 2, 2012 Report Posted January 2, 2012 ported, not ported? carbs, jetting? fuel type? pipes? until all those are answered the timing is somewhat irrelevant. the timing you need will be a result of the entire set up AND the type of riding you do, which will determine the amout of lead time you need for your fuel burn. keep in mind if you up the compression you will need to fuel for it, meaning octane and jetting. it's more complicated than just picking a number or using someone elses number! He is right on the money with this statement Quote
akelly000 Posted January 2, 2012 Author Report Posted January 2, 2012 Ok sorry for lack of info. Aggressive port job, dual 35mm flatslide carbs, no airbox, 155 mainjet, T6 exhaust, silly lil boost bottle, 6" filters, right now running 91 40:1, compression 145-150, 22cc domes Quote
akelly000 Posted January 2, 2012 Author Report Posted January 2, 2012 Also, I only ride in the sand. Pretty much wide open throttle always Quote
