clutch vent leak, but not out of tube
remi_357
hello everyone, my 2000 banshee has started leaking oil out of the clutch vent. It is not leaking out of the tube, however it is leaking between the nipple and the engine case. Is there a bad o ring? Im new to banshee's and have never taken one out.
Would a block off plate be the best solution for fixing this?
thanks
thanks
thats what i would do. i just bought one off ebay for 8 bucks
yep, unfortunately it installs from inside the cover.
If you are careful you might be able to remove the cover without damaging the gasket. I've used the same gasket many times over, just be sure to grease up the gasket prior to installing.
Personally I wouldn't use RTV instead of a gasket, worth a try though...
