Hi guys, I've pull my water pump apart to find that the plastic impeller is rubbing on the metal plate cover. See picture
Should I be replacing this with a new one or is this normal? First time pulling it apart so in not sure if it's ok or not.
go with a aluminum one i exploded two stock ones . I run a mull gear to ill never go back to stock junk.
there isnt anything that keeps it perfectly centered. it kinda floats in there, some rubbing will happen. replace with new stock and enjoy. theres a reason why its plastic.
