BansheeWA Posted December 1, 2011 Report Posted December 1, 2011 So I'v just recently done quite a few mods to my stock banshee and i feel like it's running a bit to hot, i Just would like to know what's the best way to go about this to get her running a bit cooler? Quote
Zwiser Posted December 1, 2011 Report Posted December 1, 2011 did you rejet the carb? what all did you do? Quote
donkeypuncher Posted December 1, 2011 Report Posted December 1, 2011 Jet it a tad richer, aftermarket radiator, billet water pump impeller. Quote
BansheeWA Posted December 1, 2011 Author Report Posted December 1, 2011 V force reeds K&N pod filter Timing +4 R2 pipes And yea i did rejet I't i put 300 mains and 30 pilots I'n, I was thinking the aftermarket radiator n billet pump to. Quote
Coupelx Posted December 1, 2011 Report Posted December 1, 2011 your thumb. open it up and get some air moving. Quote
Zwiser Posted December 1, 2011 Report Posted December 1, 2011 do you have a temp gauge to confirm that it really is running hot? or do you just think it is? Quote
BansheeWA Posted December 1, 2011 Author Report Posted December 1, 2011 No I'm I'n the process of getting a temo guage, ever since i have put those mods on the 1st run i did the black paint on the top end of the motor started to discolor that's why i am thinking it's running hot because that never happend before? Quote
Zwiser Posted December 1, 2011 Report Posted December 1, 2011 did you do a leak down test? plug chop? if your still running a stock impelor i would strongly suggest getting a billet one from chariot, and silicone lines help alot too. Quote
Zwiser Posted December 1, 2011 Report Posted December 1, 2011 you have to also remember that if you get a bigger rad that the water flow will decrease but the coolant wont get as hot as quickly. so if your stock rad is not all bent to hell and its working right, its not a problem Quote
Judge1 Posted December 1, 2011 Report Posted December 1, 2011 (edited) I can tell you what not to do....Engine Ice. It is over priced bullshit and doesn't lower the temps it claims to! Ahh the power of marketing. Edited December 1, 2011 by Judge1 Quote
BansheeWA Posted December 2, 2011 Author Report Posted December 2, 2011 Plug chop as I'n checking the spark plugs? After i jetted I't i took I't for a quick squirt and the plugs were a light goldy colour, then went for a 30 minute ride which i was supposed to check the plugs but haven't had time as of my misses banshee has broke and i have been trying to work that out since last weekend. Quote
06specialedition Posted December 2, 2011 Report Posted December 2, 2011 Chariot makes a nice water impeller Quote
N2deepRacing Posted December 3, 2011 Report Posted December 3, 2011 I have a nice fuildyine(spellcheck) rad for sell. Its polished. $200 let me know Quote
BANSHEE HP Posted December 3, 2011 Report Posted December 3, 2011 fuel is the best product to can add... Quote
camatv Posted December 3, 2011 Report Posted December 3, 2011 coup hit on the head. ride faster. i have. stock rad, stock impeller, 50/50 mix of cheappo coolant, gas and i ride the bike fast NEVER overheated.. DONT run straight water. DONT use tap water. mix 50/50 coolant at least with distilled water. if you want to impress your friends buy food coloring and change the color of the coolant ( i've heard blue is neato) Quote
