thomas h. Posted November 17, 2011 Report Posted November 17, 2011 First day at glamis was great. Half way threw 2 nd day it started a poping maybe like a lean pop in 2 nd and third gear going up hill. So I babyed it back to camp. Going to build a leak down tester but mean while any thoughts? Look it over for air leaks but nothing. Quote
wacko2000 Posted November 17, 2011 Report Posted November 17, 2011 Thomas, I know you are running stock carbs, i believe yfz airbox and filter What jets are you currently running? Joe Quote
Dicklez Posted November 17, 2011 Report Posted November 17, 2011 Clean your jets. Last ride mine started leaning out and popping. I found tiny piece of grit in my main jet. Quote
firebanshee Posted November 18, 2011 Report Posted November 18, 2011 Possible bad spark plug cap (blown resistor) Quote
thomas h. Posted November 18, 2011 Author Report Posted November 18, 2011 Thomas, I know you are running stock carbs, i believe yfz airbox and filter What jets are you currently running? Joe Hey wacko this is about my brothers banshee stock carbs k&n carb where just cleaned but ill check anyway. Someone else also said spark related. The 5k caps are new. But I'll check them. The spark plugs look tan on the electrode. I'll check other eletrical stuff too. Quote
