THE358BANSH Posted November 17, 2011 Report Posted November 17, 2011 Does anyone know of a manufacturer that carries manifolds for 40mm and larger carbs on a stock sized reed cage? Or another option would be a billet style manifold that uses the VM40-200k style boots? Thanks a bunch! Evan Quote
THE358BANSH Posted November 17, 2011 Author Report Posted November 17, 2011 these are for 38-41mm - boss intake http://www.alibaba.com/productshowimg/us108193968-262465984-0/BOSS_Intake_Manifolds_for_38_to_41mm_carbs.html these are for 36-41mm - trinity http://www.ebay.com/itm/Banshee-YFZ350-RZ350-Billet-Intake-Manifolds-w-Boots-36mm-38mm-39mm-41mm-/350498821527 38-40,, - modquad http://www.roguemotorsportz.com/i799/Modquad_38_40mm_Split_Intake_Manifolds_no_spacer_Yamaha_Banshee.aspx Those all use the VM36-200K intake boot and get stretched heavily to fit big carbs. Quote
No Limit Powersports Posted November 17, 2011 Report Posted November 17, 2011 The vm36 boot will fit a 40mm carb just fine in fact thats what there made for. You dont want them loose or they could leak and/or fall out of the boot. Quote
THE358BANSH Posted November 17, 2011 Author Report Posted November 17, 2011 The vm36 boot will fit a 40mm carb just fine in fact thats what there made for. You dont want them loose or they could leak and/or fall out of the boot. I know they were built for the 38-41 PWK carbs which have a manifold side OD of 46mm. I guess I should have reiterated myself and said 40mm and larger Mikuni and 44mm and larger Lectrons which are 52mm on the manifold side and most commonly use the VM40-200K flange. Quote
camatv Posted November 20, 2011 Report Posted November 20, 2011 make your own. UPP's are pretty big and there is barely enough room for bolts to mount them to the cylinders.. Quote
THE358BANSH Posted November 20, 2011 Author Report Posted November 20, 2011 make your own. UPP's are pretty big and there is barely enough room for bolts to mount them to the cylinders.. I called UPP the other day and talked to a tech guy. The inside diameter of their largest intake is 46mm and he said he thinks it would stretch 2mm max. Oh well, guess I either have to cut the throttle bodies in the lathe or search for a set that has a smaller outside diameter. Quote
