shee06 Posted November 6, 2011 Report Posted November 6, 2011 I have pistons that the top says .50 does this mean that the piston is oversize? any in put is greatly appreciated thanks Quote
slacker1bob Posted November 7, 2011 Report Posted November 7, 2011 I have pistons that the top says .50 does this mean that the piston is oversize? any in put is greatly appreciated thanks Yes, means .5mm bigger, so 64.50 Now, if you typed or read it wrong, it could be .050" bigger which is 65.25mm piston. .010" =.25mm Quote
shee06 Posted November 8, 2011 Author Report Posted November 8, 2011 Yes, means .5mm bigger, so 64.50 Now, if you typed or read it wrong, it could be .050" bigger which is 65.25mm piston. .010" =.25mm okay thanks for the response would i be able to just have my cylinders hooned and re ringed or would i have to go up it size again? Quote
