Does anyone have a Aftermarket/Performance 8 Plate Inner Clutch Hub that is used that they can cut me a deal on? I looked on eBay and WOW Hinson is very proud of there Hubs. I talked to Driveline and Mattoon and they both told me that Hinson was only company they knew of that made a Inner Hub that would hold 8 Plates, does any one know of a company other that Hinson that makes one of these Hubs? I just liquidated a lot of my old unused Banshee parts on eBay and bought all new Clutch Components for my Banshee. I went a little over board but I didn't want to take any chances. Horse Power is useless unless you can get it to the ground and I'm hard on Clutches and I hope this new set up takes care of it for good. The kit I'm putting in the should hold 150+ Horse Power. The Clutch Components I've bought so far are listed bellow:
  • DRIVELINE STEALTH LOCK UP
  • DRIVELINE 8 PLATE EXTREME DUNE AND TRAIL CLUTCH KIT
  • MATTOON EXTREME HEAVY DUTY 8 PLATE BILLET CLUTCH BASKET
%21Bb2PQr%21BGk%7E$%28KGrHqEH-EMEqtp%29BBrLBK%297H%21Cz%28%21%7E%7E_12.JPGa20791512c4db0e566ef5_m.jpg%21BRlw01gBWk%7E$%28KGrHgoH-DoEjlLluCsSBJ-0LN%29u1%21%7E%7E_12.JPG
All I have Left is 8 Plate Inter Hub, I'm hopping you guys can help me. I ran Lucas Full Synthetic SAE 10W-50 Motorcycle Oil for Wet Clutch Applications in my Transmission mixed with 2oz of TWO2COOL Transmission Coolant Additive and I had pretty good luck out of it with my Stock .020 Cylinder Set Up, so I plan to keep using that mix in my Transmission with this new Serval Cub. I also Run a Stream-Line Hydraulic Clutch Lever and Slave Cylinder. Anyway please let me know if any body has a 8 Inner Plate Hub or knows any body other than Hinson that might make one that doesn't cost so much.
____________________________________________________________________________________________________________________________________________________________________________________________
298387_10150332723424828_742274827_8056875_224961406_n.jpg314059_10150321391264828_742274827_7993615_1296091026_n.jpg 314059_10150321391279828_742274827_7993618_2088875377_n.jpg
