mikey7o2 Posted October 17, 2011 Report Posted October 17, 2011 first i want to say thanks for all the help with my last post!! i just bought a 97 banshee with a bad #2 cylinder the bottom end is fine and it has a hot rods stock crank and connecting rods. it also has a PTR cool head with 17cc domes, a set of PTR hi rev pipes, and a keihin twin carbs set up. what i need to no is can i ues any of the parts that made it threw the burnt #2 piston, or should i start from the begging? i dont want to go with the tt style motor but i do plan on lowering it and putting some street tires on it. any help on where i should start looking and what kind of motor i should look to build would be a great help !!!! thank you Quote
jonvia Posted October 17, 2011 Report Posted October 17, 2011 first i want to say thanks for all the help with my last post!! i just bought a 97 banshee with a bad #2 cylinder the bottom end is fine and it has a hot rods stock crank and connecting rods. it also has a PTR cool head with 17cc domes, a set of PTR hi rev pipes, and a keihin twin carbs set up. what i need to no is can i ues any of the parts that made it threw the burnt #2 piston, or should i start from the begging? i dont want to go with the tt style motor but i do plan on lowering it and putting some street tires on it. any help on where i should start looking and what kind of motor i should look to build would be a great help !!!! thank you id say send your cylinders off to get a full drag port, and some shearers or r2's with the cool head. idk just my .02 lol Quote
EvilBanshee Posted October 20, 2011 Report Posted October 20, 2011 What do you mean by "StreetABLE"??? Quote
dcalsv02 Posted October 21, 2011 Report Posted October 21, 2011 How Much for the paul turner high's? Quote
volcrano Posted October 22, 2011 Report Posted October 22, 2011 421 cheetah cub ported powervalve motor.then run a tall gear for cruising without running high rpms,but still have a powerband that is useable and power to pull a tall gear.prob gonna have to change carbs too depending on what they are. Quote
mikey7o2 Posted October 30, 2011 Author Report Posted October 30, 2011 hey sorry its been so long i have been hella busy i tried to load my pics but it says the file is to large ! and ill sell what ever i cant use and what i mean buy streetable is i want to lower it and put street tires on it and use it mostly and a 1/4 mile track but also be able to go to a street track and be able to at least compete ! angin all the help is very welcome ! Quote
mikey7o2 Posted October 30, 2011 Author Report Posted October 30, 2011 421 cheetah cub ported powervalve motor.then run a tall gear for cruising without running high rpms,but still have a powerband that is useable and power to pull a tall gear.prob gonna have to change carbs too depending on what they are. it has a twin carb steup from paul turner im not sure how to tell what size they are Quote
mikey7o2 Posted October 31, 2011 Author Report Posted October 31, 2011 i put pics of my banshee on photobucket her is the link http://s1137.photobucket.com/albums/n506/mikey7o2/my%20banshee%20tear%20down/ Quote
