Decided it's time for a new project, so the Banshee's gotta go. Everything listed is in mint - near mint condition... It was torn and completely rebuilt from top to bottom last winter, then made it to the dunes once(main reason for letting it go). The prices listed below do not include shipping or paypal, contact me for total prices shipped.
I am parting the motor due to something being sucked into the left cylinder and damaging the piston/head. There was no other damage to anything whatsoever. This motor has gone 4.12 in 300'. Bores are fresh from fast and have about 4hrs total run time on them.
Havoc 4mill Drag Port Cylinders with spacer plate - $650 (will include 1 piston and rings, just need to replace left side piston and you're good to go)
-A link to at least a few comments about this motor, I'm sure there are more that will vouch for it... http://bansheehq.com/forums/index.php?showtopic=145539&st=0&p=1254763&fromsearch=1entry1254763
Perfect Port Matched Cases clean with no chain break(will come with all bolts and nuts) - $250
New Style Vitos 4mill 110rod crank, was installed brand new with the rebuild last winter - $350
1-5 N Down Duneable - $350
VF2 Reeds Need Replacement Petals - $40
Billet Intakes... Fit my 34's, probably a 34-36 boot - $50
34mm ALKY PJ's with Powerjets and Chariot Billet Bowls - $250
Stator with Pro-design Timing Plate - $125
Shearer Small Bore Small Flange In-frames w/nickle plating, chrome Stingers(need cleaned maybe re-chromed) and shearer billet Silencers - $400 (will include clamps, hangers and good springs)
Lonestar +2+1 A arms, fresh gloss black pc, small scuff on bottom of right lower arm, no bends dents or other scratches/scuffs... about 10hrs on them since new - $400 (with braided lines, tie rods/ends and ball joints)
Elka Stage 2 piggyback Dune Editions valved for 200lb rider... mint with about 10hrs on them - $500
Stock rear shock with the total treatment from SoCal Custom Suspension... rebuilt, revalved, polished, new black Eibach spring, set up for +6 swinger - $350 (4hrs on it)
Polished Dog Bone Link, Has some dings but still looks good - $40
Stellar +6 swingarm with mint gloss black pc, mirror polished RAD carrier, brake plate, dust caps, all hardware and chain guides - $425
RPM adjustable axle... clean and straight with billet locking nut - $200
Front Hubs and spindles... Fresh metallic gray pc, new bearings and seals - $75
Rear Hubs... Fresh metallic Gray pc - $50
Front Calipers... Rebuilt, Fresh Gloss Black pc, good pads - $100
Rear Caliper... Rebuilt, Fresh Gloss Black pc with billet block off - $75
Full set of Dirt tires... Dunlop KT355 20x10x9 rears and KT331 21x7x10 fronts all on Douglas Red Labels, tons of tread, no dents in rims but the finish is not perfect. Best hooking tires I've used - $200
22x11x8 SLS 12 paddle Extremes with mohawk fronts lightly buffed to match... Rims/Tires are mint with the exception of a lip bend on the inside of one of the fronts(does not lose air) all bought new and saw the dunes once - $600
Complete Set of black Maier plastics... some scratches on rear fenders but still glossy, everything else was bought new not too long ago and are near mint - $325 (might want to do pick up only on these)
Stock Steering Stem with Mint gloss black pc - $50
Metallic Gray pc'd '96 frame, mint aside from a couple scuffs from the motor install/removal, usual suspects were cut off before pc, new stem bearing and seal - $200 (never had a title for this, bos only, again probably pick up only)
All Black seat with no flaws - $50
Newly purchased Pro-Taper mid bends with ODI clamp on grips - $50
Throttle Block with polished billet cap and billet extended lever - $50
Polished Billet Rear brake Res - $45
Polished Roll Design Brake Lever - $40
CDI - $75
Clean Clutch Cover with good seal, bearing and stainless hardware - $30
Stator Cover with good gasket and stainless hardware - $20
Gas Tank with Dual Pingle with billet iron cross cap and braided vent hose - $100
Billet Flame Bar Clamp - $40
Sparky Spark Arrestors... Have them fitted with hi-temp hose so they just slide onto the shearer silencers without scratching - $50
If you see anything you need that isn't listed, please contact me for price and availability.
A few pictures of the bike fully assembled below, will get individual part pics up asap. All parts are located in Edwardsburg, MI and available for local pick-up.
These are not the new bars in the listing, will have pic up of those soon
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
too clean to part out for sure!!
If I didn't have to tear the motor down to inspect I definitely would have tried to sell it whole. Just don't have the time to put it back together right now and antsy to get started on my sled and 450
