Hey guys, this might be a stupid question but I have no idea. If you bore your banshee out to say .40 over or any other size, is there any way you can go back to the stock bore size? What do you have to do and about how much does it cost?
You would have to have your cylinders resleeved to go back to stock bore. Once you bore a set of cylinders there is no turning back. Its cheaper to just by another set of cylinders used.
So all you need to do is Get a new cylinder sleeve ?
you have to take it to a company who does that kind of work...... then they take your clyinders and heat them up while cooling down the sleeve... then they will insert the sleeve into the cylinder that you have for them and line up the intake and exhaust ports. its not as easy of a task as it sounds. This is why its usually cheaper to just find a good set of used cylinders than it is to have your cylinders sleeved...
Okay, thanks
