Max S Posted September 28, 2011 Report Posted September 28, 2011 Some people know to check to see if there startor is on proper timing and its got good ohms, same with the Tors switches, check everything for proper ohms. still got no spark? check play in throttle, if theres alot it my activate the handle tors switch at the wrong time. make sure your throttle play is tight Quote
J-Madd Posted September 28, 2011 Report Posted September 28, 2011 - Timing has nothing to do with the spark. It will still spark if the timing is all jacked up, just won't start. - The first thing you do with TORS is unplug it and throw it away, then the throttle cable play has no effect on the ignition. There is a lot more than what you listed to troubleshoot absent spark. Quote
n2otoofast4u Posted September 28, 2011 Report Posted September 28, 2011 Some people know to check to see if there startor is on proper timing and its got good ohms, same with the Tors switches, check everything for proper ohms. still got no spark? check play in throttle, if theres alot it my activate the handle tors switch at the wrong time. make sure your throttle play is tight Will one of the mods please delete this.. This is about as useless as it comes. Quote
apeik Posted September 28, 2011 Report Posted September 28, 2011 sounds like pro tips from bansheeboys or whatever from atlanta lol Quote
dirtydownunder Posted September 28, 2011 Report Posted September 28, 2011 http://bansheehq.com/forums/index.php?showtopic=133650 Quote
