well.....the slides are side specific because of the nubs on the interior walls of the carbs, however you can put the carb slides in the wrong carb 180* backwards....so then the halfmoon cut out would be forward when it needs to be pointing out the back of the bike.
Also the choke carb (left side carb) has all the choke internalls which are even included in the pickup tube that is in the carb bowl....... so the carb bowl with the small brass ball or "BB" needs to be on the left side carb.
