• Stock-Stroke, 65.5mm Bore
• Dune-Port from Kevin Herr @ HJR Racing in Encinitas California.
• Pro-Design Cool Head w/ 20cc Domes
• Wiseco ProLite Piston Kit (less than 10hrs on new top end rebuild)
• Boysen Epoxy Reeds on the stock cages
• Billet Clutch Basket
• Cascade Billet Water-Pump
• Modified Shift-Star
• New OEM Shift Forks & Rods (Same run-time on these as top end)
• Cascade Pancake Bearing
• Bead-Blasted OEM Cases
• DG Billet Case-Guard
• Pro-Design Billet Adjustable Timing Plate
• Tusk HD Clutch Kit
Stock black Stator cover, bead-blasted stock clutch cover w/ billet water-pump cover & billet clutch cover insert. Every seal replaced when engine was built. All transmission bearings are new. Engine is super clean. Not a single problem, ready to run. Stock carbs w/ TORS elim kit and idle screws available for a little bit more. FMF Fatty Gold Signature series pipes also available for a little more. Engine is complete, ready to bolt in and run.
$1000 + shipping
Edited by BigRed350x
$1000 + shipping
I'll take it. PM on it's way
