So the day before yesterday i rode my bike down the rd and back and everything was fine. After that i washed it and let it sit for a few hrs came outside to start it and nothing. filters are dry, carbs have been cleaned out multiple times now, swapped to a known good coil, stator is dry, tried diff gas and pull starting doesnt work.
Is it getting spark?
Do the plugs smell like gas?
Did you turn your fuel petcock off and forget to turn it back on? (It happens, not an insult)
Choke crossover tube come loose?
Hows the compression?
Does it sputter at all or do you get nothing? (Flywheel key)
Kill switch bad? Key on if you still have it? Tether?
oh yeah, check your reeds too.
Edited by jlsparky7
its getting spark
petcock is on
crossover tube is good
compression is fine
its sputtered a few times when trying to start
has a tether i bypassed that..
Plugs smell like gas? Tried starting fluid? New plugs? Engine compression?
Edited by jlsparky7
have you tried turning on the key? kill switch in the "ON" position?
believe it or not, that has been the root of some ppls problems
no key just tether and if the key was off there wouldnt be spark..
spray some carb cleaner on your air filter and kick start it. if it don't start you probably have a spark issue. just my .02.
tried that. got a cdi on the way if that doesnt work i ill get ANOTHER new stator
