barahonapr Posted September 20, 2011 Report Posted September 20, 2011 I did search and could not find the size of stock rims. Im trying to buy new rims and tires and was wondering what they were. Thanks guys Quote
BansheeTeD Posted September 21, 2011 Report Posted September 21, 2011 stock tires : front AT21 x 7-10 back AT20 x 10-9 Quote
barahonapr Posted September 21, 2011 Author Report Posted September 21, 2011 Now is that the tires or rim? I was looking for the rims..sorry if its a dumb? Quote
barahonapr Posted September 21, 2011 Author Report Posted September 21, 2011 Well I can't find any stock 9×9rims but there's 10×9 but all those have offsets Quote
barahonapr Posted September 21, 2011 Author Report Posted September 21, 2011 I guess what im trying to figure out is uptown what offset can I get on a stock axle without having to get spacers. Quote
robert.b.west Posted September 21, 2011 Report Posted September 21, 2011 The first number is the diameter the second is the width. So if you are using the same tires a 9x8 rim will work. And most likely they are going to have a 3+5 offset. Which means that you have 3 on the inside and 5 on the outside. These will probably make your back end a little wider. Quote
barahonapr Posted September 21, 2011 Author Report Posted September 21, 2011 So I can get 10×9 rims with that offset on a stock axle? Quote
robert.b.west Posted September 21, 2011 Report Posted September 21, 2011 So I can get 10×9 rims with that offset on a stock axle? Are you getting new tires with a 10" run hole? Quote
barahonapr Posted September 21, 2011 Author Report Posted September 21, 2011 Yes I will be buying new tires also Quote
robert.b.west Posted September 22, 2011 Report Posted September 22, 2011 That could work you would just have a large wheel. Quote
