stock rim size
barahonapr
The first number is the diameter the second is the width. So if you are using the same tires a 9x8 rim will work. And most likely they are going to have a 3+5 offset. Which means that you have 3 on the inside and 5 on the outside. These will probably make your back end a little wider.
