I have a banshee I bought and rode like twice then the piston blew up. I took off the jugs and seen it has a hot rod crank. C.k.158 b. I need to no if its stock stroke or a long rod crank. Can any one help
its hard to tell hot rods changed there cranks at some point but if im not mistaken a ck158b is a 4 mill what are the numbers on the pistons that will help alot.
put ur cylinders back on with pistons installed and use some thing that read mm and measure how far the piston moves up and down in the cylinder
