wy you sell it ???? vitos crank?? any spacer with or can you tell me what you need to put that crank and not run any spacer put a 795serie piston what kind of dome you have to use stroker or stock dome for cool head ???
I was going to use this in my rz350 but have changed my mind. You can use regular pistons and just cut 80 thousandths out of the head.That way you don't need a spacer plate and it won't change your port timing.
Ummm not so sure about the statement that port timing won't change by cutting .80 off the head. I assume you mean cut the dome .080 higher so that the piston can stick out of the cylinder. Even so, port timings WILL change with longer stroke.
