350twinSA Posted September 7, 2011 Report Posted September 7, 2011 Afternoon BB 1: We rode our quad with one of the axle nut's loose,which in turn ate up the spline holding the wheel hub and axle together. Can this be welded together,and will it be a viable solution for use on trails(I hardly ever jump my banshee) 2. Just installed a used rpm dominator axle,I purchased with it a new hub for the right wheel,and the left hub i am still using the old hub from my stock axle.There is a little bit of play on the left wheel hub.should I replace the wheel hub or is it fine?the play is very slight,however I do not want it to ruin the splines on the new axle. If I should replace,who here willing to ship it to me in SA? TIA Quote
NYUK Posted September 7, 2011 Report Posted September 7, 2011 you can weld the hub on, but both will be trash later. i have 06 rear hubs and will ship to sa. Quote
350twinSA Posted September 7, 2011 Author Report Posted September 7, 2011 you can weld the hub on, but both will be trash later. i have 06 rear hubs and will ship to sa. ok,with regards to welding,I do not want to do that to the dominator axle.Should I get a new hub to fit on there? I do however want to weld a hub onto my old stock axle. Price + shipping to SA?Condition? Quote
NYUK Posted September 7, 2011 Report Posted September 7, 2011 yeah weld the old stocker. get newer hubs for the dominator. shipping priority to sa is 45.. hubs 25. Quote
Man-O-Steele Posted September 8, 2011 Report Posted September 8, 2011 ok,with regards to welding,I do not want to do that to the dominator axle.Should I get a new hub to fit on there? I do however want to weld a hub onto my old stock axle. Price + shipping to SA?Condition? how are you going to take the axle out later if you weld on the hub? Quote
camatv Posted September 8, 2011 Report Posted September 8, 2011 grinder duhh or chop saw?? i know whenever i screw up like that i just weld it all together and worry about it later. Quote
