i think its a pretty good price. i'd say go for it....as long as you check things out first.
Check list:
-Does the guy have a title?
-Is the frame in decent shape? (check by standing it up on the rear grab bar and look at it.
-Check to make sure the front end isn't loose.
-Does the engine have good compression? (with a compression guage and holding WOT kick it until needle stops moving...on a stock bike anything about 110 is decent. 125 is usually JUST after a rebuild. around/under 90 is rebuild time) (compression may be higher if he's got internal mods)
-How are the brakes and rotors?
-Check around the frame real good a second time to see if its been cracked or repaired in any way.
After that......id say it aint a bad deal at all.
