Thewhite Posted December 1, 2011 Report Share Posted December 1, 2011 Do a search under my name. I did a compete RZ conversion back in 2006 and the quad has been absolutely flawless. Motor work was done by Patriot Racing/MX mods, estimates horse is 72 and torque is around 45lbs. Compared to my other banshee that has almost the exact same mods the RZ is insane to ride. Mounting all the electonics isn't that difficulte. Put the servo on the right side of the frame up by the ignition coil, battery eliminator on the right side of the aribox on the frame. CDI mounted to the back of the airbox, rectifier and the PV control motor where the current banshee CDI and voltage regulator is held. Clean set up. You won't be dissapointed. To be honest, the RZ has great low end but you will need to experment with the external gearing. I use the RZ internal gearing with a 14-41 external gear combo. Compared to stock gearing on a shee with this set up 1st gear on a RZ feels like between a 1st and a 2nd on the shee. This the same feeling till you get to 6th. From 5th to 6th the gearing seems close. People say the RZ motor with the Powervalves smooths the power delivery I feel just the opposite. The set up the Dan at Patriot Racing set up with just flat out rocks. Motor pulls much harder than my other shee. Not mellow at all. Yaxy what pipe are you using ? what carb and jetting? I'm using stock banshee gear ratio with 15-41 sprocket. Banshee Tranny Ratios: 1st-- 2.461 2nd-- 1.812 3rd-- 1.500 4th-- 1.250 5th-- 1.045 6th-- 0.875 RZ 350 Tranny Ratios: 1st-- 2.571 2nd-- 1.778 3rd-- 1.318 4th-- 1.083 5th-- 0.962 6th-- 0.889 Quote Link to comment Share on other sites More sharing options...
Yaxy Posted December 1, 2011 Report Share Posted December 1, 2011 Rocket pipes 28 Flatside carbs Jetting, 340 main, 20 pilots 14-41 external gearing Quote Link to comment Share on other sites More sharing options...
