Pat the one the only Posted August 23, 2011 Report Posted August 23, 2011 i did a cases up rebuild on the banshee and its been together for a month with no problems, and then i was riding at a buddies and as i went to put it away it ran like shit, i shut it off, and after we got the hay in, i started it and it ran like it was out of time, it backfired, then wouldnt rev up, then shut off and wouldnt start. its got spark, gas, and compression, the timing plate and flywheel are tight, and its got tors removed, idk what it could be, please help Quote
bansheesrtoys Posted August 23, 2011 Report Posted August 23, 2011 what type of filter do you run and do they have pre-chargers? maybe even bad plugs?if they have pre-chargers try taking the pre-chargers off and see it makes a difference. Quote
Pat the one the only Posted August 23, 2011 Author Report Posted August 23, 2011 what type of filter do you run and do they have pre-chargers? maybe even bad plugs?if they have pre-chargers try taking the pre-chargers off and see it makes a difference. twin air with no prefilter, no problems there, and i swapped plugs with no luck Quote
03 turbo Posted August 23, 2011 Report Posted August 23, 2011 thats funny the prechargers never heard that one when it backfires just about everone will say its in the electrical system stator,cdi, coil or a bad ground try and swaping parts with a buddy Quote
Pat the one the only Posted August 23, 2011 Author Report Posted August 23, 2011 thats funny the prechargers never heard that one when it backfires just about everone will say its in the electrical system stator,cdi, coil or a bad ground try and swaping parts with a buddy my stator is waterproofed, i didnt hit any water, and the cdi is recent, idt anything should have gone, unfortunatly i dont have a buddy to swap with that has a banshee Quote
bansheesrtoys Posted August 23, 2011 Report Posted August 23, 2011 yeah well i been drinking. but as far as not reving part thats why i saud that plus it easy and don't cost anything to try. Quote
Phelps Posted August 23, 2011 Report Posted August 23, 2011 take the flywheel off and make sure you didn't shear the key. also make sure the stator plate didn't come loose. Quote
Pat the one the only Posted August 23, 2011 Author Report Posted August 23, 2011 take the flywheel off and make sure you didn't shear the key. also make sure the stator plate didn't come loose. the stator plate is tight, and i turned the motor over using the flywheel so i dont think i sheared a key, good thought tho Quote
03 turbo Posted August 23, 2011 Report Posted August 23, 2011 a stator can go at anytime new or old i have had it happen new less than 5 hours old Quote
Pat the one the only Posted August 23, 2011 Author Report Posted August 23, 2011 a stator can go at anytime new or old i have had it happen new less than 5 hours old its got fat spark though Quote
Pat the one the only Posted August 23, 2011 Author Report Posted August 23, 2011 just because you can turn the motor off with the flywheel doesn't mean you didn't shear the key. hmm im deff going to check both tommorow, any other possibilitys? Quote
Pat the one the only Posted August 23, 2011 Author Report Posted August 23, 2011 Reeds? maybe, but i dont hear any odd noises when i turn it over, this is a puzzler.. Quote
Pat the one the only Posted August 23, 2011 Author Report Posted August 23, 2011 i checked and i didnt shear a key, i have fat spark, and the plugs are good Quote
DuneBooZeR Posted August 23, 2011 Report Posted August 23, 2011 Have you tried to pull start it? Quote
