banshee_kills Posted August 17, 2011 Report Posted August 17, 2011 I got a new clutch kit, and i was wondering what would be the best oil to soak the friction plates? any help would be appreciated Quote
SandmanPNW Posted August 17, 2011 Report Posted August 17, 2011 I got a new clutch kit, and i was wondering what would be the best oil to soak the friction plates? any help would be appreciated Gear Saver Quote
banshee_kills Posted August 17, 2011 Author Report Posted August 17, 2011 Gear Saver Thanks :-) Quote
#1JUANstunna Posted August 17, 2011 Report Posted August 17, 2011 Soak them in the same thing you are going to run in the bike. Quote
spurdy Posted August 17, 2011 Report Posted August 17, 2011 Soak them in the same thing you are going to run in the bike. X2 Quote
banshee_kills Posted August 17, 2011 Author Report Posted August 17, 2011 Soak them in the same thing you are going to run in the bike. Oh alright bro thanks Quote
Trueblown Posted August 17, 2011 Report Posted August 17, 2011 Only use what you are going to run them in otherwise you are just wasting your time since they will be put in something else anyways Quote
Trick2stroke Posted August 20, 2011 Report Posted August 20, 2011 It's common practice to soak them in what you will be running, however, if you soaked them in a different oil it's not going to fuck anything up. I soak mine in Amsoil Severe Gear since that is what I run. You will get a hundred different answers and 99% of them will work just fine. Quote
