axel bearing removal
i am powdercoating my swingarm so i want to powdercoat the axel bearing housing as well i was just wondering what the best way is to remove the bearings inside the housing without messing them up also if anybody has a used set of aftermarket a arms they want to sell let me know
Only 1 way to get them out. Push the inner spacer tube to the side, and use a long punch to drive them out. Go back and forth on each side of the bearing. You can do what you want, but I wouldn't reuse the bearings. You're pounding on the inner race which is pounding on the balls. New bearings should be installed with a hydraulic press, pushing on the outer race only. Then put in new seals. Do it once. Do it right. Forget about it.
While you're at it add a zerk to the carrier, pull the seal off inner side of bearing. Keep her full of grease to keep that nasty Yooper mud out. :jesterlaugh:
lol what all do i need to take out of the housing to powdercoat it? just the outer axel bearings or is there more on the inside that needs to come out
only ways are a slide hammer, which probably won't work good, and as mentioned, a drift through the collar, and work it around. just pick a good spot in the middle for the zirc, and get yourself a 1/4-28 tap *(iirc) and a grease zirc that fits. you want to pull the plastic shields off the bearings when you do this, so grease actually gets to the balls. can't have bare balls, ya know.
