Simple question but does anyone know where I can find the "flange washer" that fits on the swing arm and goes through the mounting plate for a round house swinger rear brake caliper?
When you upgrade from a banshee stock swinger to a round house honda style swinger, then you buy the rear brake mounting plate. I need the spacer with the flange that fits between the plate and the rod welded to the swinger.
Is this a Honda part or do the vendors carry it or can you find it at a hardware store?
should come with the swing arm?
some carriers might have it with them or you will need to make it you can also try acn call some swingarm buildersand see if they will sell it to you.
Thanks. I have the whole setup but the special "flange washer" is missing. That is the only piece I need. I will try the places listed above.
