AKheathen Posted August 16, 2011 Report Share Posted August 16, 2011 you also have to concider a few things- 100 could be good, as long as the numbers are close, and your compression tester should thread down into the cylinder as far as the spark-plug, with a shrade valve at the tip. Quote Link to comment Share on other sites More sharing options...
3Yamaha5Banshee0 Posted August 16, 2011 Author Report Share Posted August 16, 2011 i havent tore into it yet but this winter (if i make it that long) im going to tear it all apart and see whats going on. i hope i can just hone the cylinder and put new rings and a gasket set on the top end and we will be smooth sailing Quote Link to comment Share on other sites More sharing options...
